door hinge mounts cracked
Re: door hinge mounts cracked
well, here it is, pictures and all. Be glad, very-very glad if this never happens to you.
http://flumichigan.italiancarclub.com/T ... repair.pdf
Very impressive turorial Mike. Nice job.
I hope I never have to refer to it.
Ron
Ron
thanks, ron. I hoped i'd never have to go thru the process either....but we cannot stop certain ageing processes.
Hey Mike. You did a great job on the tuitorial. Your pictures and tips are going to be a big help. This is my next "big" project on the Spider. Thanks
Dan
Dan
You're welcome Dan. I wish i could say congratulations to you, but that would not be appropriate.
Done! Thanks Mike. Just got the door remounted. It wasn't too bad getting it lined up again. Sadlly, the paint needs to be touched up.
Thumbs up on the tutorial. For newbies, knowing the road has been traveled before and the solution is very helpful.
that is the whole point behind the tutorials... letting others know that something can be done to save an otherwise gem of a car. We need to conserve our dwindling parts supply, especially the non-replaceable body parts.
- Your car is a: 1982 2000 FI
for every door that closes another is opened up....or someth
anyways i just discovered that annoying and dreaded SDDS "slacking drivers door syndrome" actually i am fortunate in that i caught it in its more nacent stage, just when the door hangs up a bit on opening as oppossed to sparks shooting whilst driving down the Freeway. So i will have to put Mike's kindly constructed fix it document to the test, will be visiting the Fiat doctor this Wed. to see what his thoughts are on carrying out the surgery. Good news is that the other door looks visually sound.............but what lies beneath is the question????????????? Will get some pics and update as things progress.
- vanover69
I know this is an old thread, but the link to Mikes instructions on repairing a cracked hinge is no longer available. does anyone have a copy they can share?
thanks
Bob
thanks
Bob
Bob, the expired link is to FLU, which is Fiat Lancia Unlimited, which later became Fiat Club of America. There is a chapter in Detroit, and my guess is that Mike Bouse is still active in that, or you could contact the chapter and they might have a copy. http://fiatdetroit.weebly.com/
I also found an email for Mike: mbouse2000@gmail.com
Not sure if the email is still valid, but it can't hurt to try.
Mike Bouse was active on mirafiori.com, but not since 2018. Not that it helps to locate him, but his address was listed as Coldwater, Michigan.
He's also famous for the "Michigan Short Shifter", a custom shift lever.
I am 'chomping at the bit' to hear if any more comes of this repost,...my drivers' side has been brazed and needs attention.
Thanks for bringing it up.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
- vanover69
Thanks for the quick reply and info
I am trying to contact Mike
If I get a copy of his document I will re share
Bob
Bob
I would love to see this tutorial document. The link does not work. Can someone repost it?? I have an appointment with a welder on Wednesday!
Rob
Rob
